Coolant
If you havnt got vacuum bleed tool get one makes life alot easier
£15 off ebay bargain!
Or the other, more expensive option.....:
Do it the old fashioned way and then immediately book yourself in for a knee operation or two! :whistling: :whistling: :whistling:
Andy6
Andy6
None of the ones I've tried to use have fitted on the reservoir! :thinking:
ad-p
ad-p
Think the ez bleed tools are only good for cars that have a screw on type cap not the twist and lock ones we have, I just use a piece of pipe with a one way valve that goes into a bottle that does the trick
Andy6
Andy6
Good tip! I was thinking of buying a new res cap, drilling a hole in it and putting the standard pressure bleeder tube through it, maybe with some rubber either side of the hole to seal it.
liffy16
liffy16
The tool I'm on about fits on caliper bleed nipple draws fluid through system
That way
