boost
  • Thread starter WARDANDRWTBY@AOL.COM
  • Start date
W
I have a evo 8 and its got a apexi avcr but when the avcr is off the boost peaks out at 0.6 bar and holds at that is that right as thought they should be 0.8 bar anybody got any ideas what it could be cheers
Dodgy sensor/gauge or possible boost leak
W
What sensor could be dodgy mate and the gauge aint that old and its a electronic calibration one if it was a boost leak then wouldnt the boost drop at it goes to 0.6 bar and holds at that
If boost continues to build and you have a leak. It will just bleed out and not increase.
Gauge could just be wrong, specially if it's electronic. I've known a good few different gauges all varying by 0.1-0.2 bar. It's nothing major and not a problem till you start pushing high boost
DaveFR
DaveFR
Mine when off stays at 0.8 bar. Agreed could be a boost leak.
Mid Wales
The actuator may be getting tired or is not pre-tensioned correctly.
W
Going to check the actuator the weekend mate but my avcr reads 0.79 kg/cm2 and my boost gauge reads 0.6 bar which would be more accurate
0.79 kg/cm = 0.77 bar
So I'd suggest your actuator is fine but your boost gauge is wrong.
W
Cheers for the info mate so the avcr is more accurate then
Mid Wales
typical evo owner, thinking theres are problem when everything is fine ;)
*whats that strange noise I just heard? :razz:
