Got youI know everything nick. Look at the bottom left of home page. New members :whistling:
he said that just before you came along nick, its like he is phychic or something![]()
Geof knows everyone lol
Got you
and he is still watching us so dont say anything else nasty :razz:
You know everything as well Leeand I wouldn't say nowt about my mate:whistling:
can we get the first post edited to include all info about this and a names list cos the thread is getting quite messy now![]()
cant edit it mate forum doesnt allow but if people were to read the posts instead of just coming on and asking questions they would see
im going to start another as it has got messy your rite![]()
To go with the ecu, then I would recommend having a walbro fuel pump fitted first, a decat (if you don't have 1 already) and some form of boost controller, otherwise the power gains will be minimal, it will just be a little more economical.
Hi guys,
Need some advise - I was always thinking of going to MADDEVELOPMENTS for a full stage 1, however it is quite pricey compared to getting a 5/6 ecu, cossie1 re map and grabing a dawes device for now (Don't get me wrong, I know Mark there is very good and you'll get your moneys worth).
All I then need to do is get my walbro fuel pump fitted proir to the day and grab the other bits. Right I've made my mind up. I'm going to do this. What needs to be done to change the pump, I've heard you need to remove the tank to do this, is that correct? If its fairly easy, I know a local chap, who does my oil changes, however for the extra money to send to mitsubishi - It might just be worth just sending to them - So sorry, any ideas on how long it would take to change the fuel pump, as I don't want Mitsubishi robbing me of there labour charges.
Cheers,
It's the ONLY way to do it imo.
I don't do the cutting lines thing, as I don't cut corners with electrics and petrol.
OK guys - Thanks or this - The chap that does my oil is pretty clued up - He normally works on modern range rovers a stuff like that - So this would be pretty easy for him with these instuctions.
So on the day, all I will need to do is fit an evo 6 ecu which I'm about to buy and the boost controller - Is it gunna be do able do you think El?
Then Cossie1 - I'll need you to re map taking into account I'm 99 percent sure I have evo 4 injectors. Any idea what bhp I should roughly achieve?
Cheers,
330 - 340bhp denpending on boost (1.2 - 1.4bar)
Cheers,
What sort of boost controller are you thinking of???
I have a couple of AVC-R's but they are expensive.
A Dawes Device will do you just fine.
I have many Gauges as you know, just not had time to email you the pics but I plan to stay at home tomorrow so will post some things up on here.
Everything is achievable on the day buddy, you will be in capable hands.
and they look the dogs too :razz::razz::razz:
As much as I would love to Geof this month, I'm gunna have to run with a cheaper controller, just tempory, but I def have one of those buggers on my list.
Cheers,
