Hi,
Thought I'd better just update the thread or I'll lose track of where I am.
Starting off with the seat rail issue, turns out the passenger side is in fact for a 7, do Ross is sorting that for me!
Started building the engine at the weekend. All was going well until I got all the crank bolted up, etc and realised I'd forgotten to put the oil squirters in!!!! With a magnet and a screwdriver I got 2 in , doing them up with a ratchet ready to torque after, until I got a bit heavy handed with 1 and snapped the bolt!
Fearing the worst and very annoyed with myself I spent all night stueing over it, thinking what if the blocks knackered etc etc...
Following morning I decided to have a poke around. Got a long flat head screwdriver down there and the stub twisted straight out! Quick phone call to super Ross and a new bolt, along with some other goodies was ordered, which arrived the next day , today.
So that's the new banjo bolt for the oil squirter, omni 4 bar map sensor and gm iat sensor ready for sd conversion and also some sealant for the sump.
So with the oil squirters now all in and torqued I cracked on with the bottom end.
Once all that was good I fitted the crank scraper.
I then set about putting the front case together but encountered yet another problem. After torquing the balancer shaft delete I discoloured the oil pump wouldn't turn !!!! It's fine with the delete piece out but in (it's very tight to get in) it hardly moves. I tried to get the oil pump off to check it but I can't get the poxy little screw out!!! I'll come back to that tomorrow as I was wound up by then.
In other news today, I got more deliveries!!!
Some bargain tyres from the Mlr group buy
And my official BAMA membership finally came through , after over a month !!!
So , current things holding me up;
Oil pump issue
Whilst taking off rear arms I've become stuck with 2 ball joint nuts half off. They may be cut off soon!
Once these problems are solved I'll hopefully really get cracking.
Stay tuned for more updates soon.
