thanks el, should be able to make the 4th, will let you no for sure by the weekend or early nextweek. Got no work for nextweek yet so just got to be careful and dont want to let you guy's down by being a no show!
OK buddy!
Geof/Steve:
What is the situation with adding another club???
Any particular one in mind???
I'll let you know if i'm in on this very soon, as it will all be down to funds - As if i'm going to do it - I'm going to go for the lot - 5/6 ECU, map, then run.
So I guess I need to get a price for a 5 or 6 ecu.
Will keep you updated guys.
Cheers,
EL might beable to help you with that 1
The evo 5/6 ecuEl??
I am on the case buddy so leave it with me!!!
Cheers,
Ok mate, it sounds like the converter has been fitted wrong, but as said a snipe of the wire should remove the speed limiter.
We'll go up there together mate if u want. If we'll going??
OK buddy!
Geof/Steve:
ok ive put the word out to indigo gt,jpoc,scooby projects ledbury. that will do for now
seems like uve done enough mate to get the numbers up![]()
