suspected diff failure
N
nick1983
Hi i'm after some advice. I have an evo4 and at first i thought the clutch was worn out but going through the paperwork it had a new one less than a thousand miles ago. The symptoms are the car drives fine but the minute the boost starts to come on in all of the gears the revs go shooting up. I have been told that this may be caused by the.rear diff having failed has anybody experianced this before? does anyone know a way i could check without having to have everything apart? Also there are no noises from anything and the clutch pedal also feels fine. Any ideas?
Launches
General abuse
Fly wheel not changed
Could all cause premature failure of a new clutch.
Also depends on what New clutch was fitted??
N
nick1983
This is one of the problems because it was done before i bought the car i don't have a clue what clutch it was as the receipt only says supply and fit 1 clutch so it isn't very informative. Plus i have no idea if he drove it everywhere like he stole it. To be honest im just looking for excuses not to have to change the clutch as all the work i do is on the freezing cold drive.
Evomad4
Evomad4
tbh id say clutch, for all u no he could of put a 2nd hand clutch in there he could of been driving it like u stole it every were.... quick way to check if its the clutch find a nice flat road get up to 30mph put her in 5th put your right foot down and watch the rev's along with the speedo you will no straight away if the clutch is slipping
That would suggest clutch, it it were diff you would know about it when the sprockets start meshing and breaking up. For all you know he could have had a pony receipt drawn up or even replaced and launched it a few times 'because he has sold it now anyways'
madhillbilly17
madhillbilly17
i would say clutch too,there are some rubbish aftermarket clutches about even with lower powered cars they fail or wear way to quick,and as said above someone mite have been launching the poo out of it lol,not sure if the other word is ok on this forum.
C
captain slow
The clutch....find a big hill get it in 4th at about 40 and floor it,it will slip it's ass off.
