To mark our company becoming an approved stockist of Superpro we have decided the best way to get these absolutely amazing products into use on your cars in a more affordable way, by offering a group buy.
im sure your all aware that on of the best modifications you can make to your evo isnt in the power department but in the handling department, so many evo's you see get power increases but then at the same time you see so many of them at sprints and tracks days powering up the main straights but then handling absolutely terrible on every corner. With my sprint car for example the biggest trio of upgrades that got me vast amounts of time of my laps were Tyres, Suspension/bushes and geometry and when replacing the majority of the bushes you realise the age of the these cars now and the bennefits that new bushes bring, no extra noise, not a harsh ride afterward but a whole better feel and more precision.
Full kits
Mitsubishi Evo 4/5/6
IT5139ADJK
Front & Rear Suspension Bush Kit (with alignment correction)
Transform the handling of your car by replacing all your rubber bushes with high performance Polyurethane bush kits from SuperPro. This kit includes our innovative range of caster and camber adjustable bush kits allowing you to change the alignment settings of the front and rear wheels. This is a must have for fast road and track prepared cars with lowered suspension. Unlike rubber which starts to deteriorate from the day it is fitted, SuperPro Polyurethane bushes are not effected when exposed to Petrol, oil, Diesel, salt, water, ultra-violet light or airborne contaminants, which means SuperPro bushes keep going long after OEM or rubber aftermarket bushes have failed. All the bushes in this kit are also covered by our unrivalled 3 Year/ 36,000 Mile warranty.
Includes:
SPF2026K Front Control Arm Lower, Rear Bush Kit With Castor Increase
SPF1715K Front Control Arm Lower, Front Bush Kit
SPF0738-14K Front Anti Roll Bar to Chassis Bush Kit
SPF2072K Rear Control Arm Lower, Shock Mounting Bush Kit
SPF2062K Rear Control Arm Upper, Inner Front Bush Kit
SPF1974K Rear Control Arm Upper, Inner Rear Bush Kit
SPF1975K Rear Differential Mounting Bush Kit
SPF2544K Rear Differential Support Mounting Bush Kit
SPF2601K Rear Toe Control Arm, Inner Bush Kit (with toe adjustment)
SPF1973K Rear Trailing Arm, Front Bush Kit
SPF2073-21KRear Anti Roll to Chassis Mounting Bush Kit
Evo 7/8/9
Control Arm, Lateral Arm, Trailing Arm, ARB & Diff Mount Alignment Kit - RS/MR/GSR
INCLUDES
1xSPF2418K
1 x DURO3741K
1xSPF2072K
1xSPF2062K
1 x SPF1975K
1xSPF1974K
1xSPF2544K
SPF2061K
1xSPF1973K
1 x SPF2489K
1xSPF1451-24K
£495 a set
Evo X
Front kit
Control Arm Front & Rear Bush Kit - Standard Alignment or caster increase
£179
Roll Centre Adjustment Kit
Extended Lower Ball joint & Bump Steer compensating track rod end - ball pin thread 12mm
£129
Roll Centre Kit
Superpro Roll Centre Kit VII - X
Now in Stock!
SuperPro Roll Centre Correction Kits for Mitsubishi Evolution VII to X!
These kits address a fundamental issue created when looking to enhance handling.
Car suspension systems have a roll centre set by chassis engineers in the design process of a vehicle to give optimum handling with minimum body roll at the required ride height and centre of gravity position.
The vehicles roll centre greatly influences how the body of the vehicle will behave when cornering and is one of the key factors in how a car ‘feels’ and how it generates feedback to the driver.
Uprated suspension on a vehicle can change the ride height and therefore change the characteristics of the roll-centre.
Contrary to popular belief, lowering a vehicles suspension does not always improve the handling.
For example, if a vehicle is lowered beyond its ideal roll centre, faster and greater levels of body roll can be generated, resulting in stability and traction being adversely affected.
The extended ball joints included in these kits compensate for changes in suspension geometry when ride –heights are lowered, counteracting the effects of the resulting repositioning of the cars roll-centre.
Consequential bump-steer issues that could be caused by extending the ball joint are corrected by the new track rod ends which are also included in the kit.
The overall effect is to restore stability and traction by achieving better tyre contact, as well as making the car more neutral and obedient to driver inputs.
£129
Rear diff Mounting kits
4 - 6 £99
7 - 9 £99
i will add all of the various pictures of the individual parts to our website over the next week or so, until then please feel free to visit SuperPro Europe Ltd - European Distributors for SuperPro Polyurethane Suspension Bushes | SuperPro Europe Ltd. to have a look further. so far we are happy to arrange for the following
any immediate purchase 10% discount
if we get x8 full kits ordered between now and 7th November 2012 a 15%
if we get x15 sets or more ordered before 7th November a 20%
** this applies to orders placed across both MLR and Evo owners forums during that timescale, along with our website, facebook etc.**
please feel free to ask any questions
