My evo 9 project
redevo
Done a deal with my modded evo 8 fq300 for my current evo 9 fq320 back in february this year, iv been gathering quite a few parts and now have started doing the work.
Here she is the day i picked her up.
This was the spec list but found out half the stuff listed isnt on car.
uprated actuator (standard)
3 port boost selanoide
decat down pipe
decat center
remapped
ap paddle clutch (exedy )
new discs
performance friction pads (standard)
hks exhaust
XYZ coilovers
fuel pump
built in knock link
I replaced the exhaust system with a 3in scorpion downpipe and wrapped it a 3in milltek decat and tsl firestorm 3in system.
I fitted a mishimoto intercooler and then visited dynotech where lee5 mapped it onto SD.
Whilst mapping there was issues with excessive smoke on overrun, yet they still carried on mapping the car and after a while decided 390bhp was all they could get due to engine issue on boost.
TBH im dissapointed in this, the car drives worse than on the original remap it had and the fact it cost me £££.
Pics of intercooler.
Here she is last saturday on the ramp at my work.
And how she stands now!
This is going to be the engine spec.
2.3 stroker
4g64 crank
cp 85.5mm pistons
oliver rods
kelford 272 cams
kiggley springs and retainers
kiggley HLA regulator
tomei scraper kit
new 3mm lash adjusters
mitsi gasket set
new oil pump
new oil filter housing
norris designs balance shaft removal kit (long shaft)
norris designs head studs
norris designs head gasket
norris designs vernier pulley
ARP main studs
ACL bearings big and main
c-tec manifold
TT S214b turbo
ID1000 injectors
Modular elbow and downpipe
modified decat
greddy titanium system
autronics SM4 ecu
Drivetrain
Rebuilt evo 7 5 speed gearbox thats covered 17k miles
competition clutch ultralite flywheel
competition clutch stage 4 6 paddle clutch kit
Hel performance complete braided clutch line
freshly reconditioned AYC pump
Brakes
K-sport 356mm 8 pot front calipers refurbished in red
brand new 355mm AP discs
XP8 or XP10 front pads
refurbished rear calipers in red to match fronts
drilled and grooved rear discs
DS2500 rear pads
Hel performance braided brake lines
new fluid
Wheels
9x18 rota force drift alloys in gunmetal ET27
255 35 18 bridgestone potenza RE050A
Inside
evo 9 FQ340 ralliart half leather interior
twin pillar pod
evo 7 dash heater control panel modified to accept gauges
defi boost
defi oil pressure
defi oil temp
defi water temp
innovate AFR gauge
redevo
That downpipe pictured is for sale as replacing with a modular elbow/downpipe.
mart1983
mart1983
you telling everyone on here! that you left it after the map! i mean it was fine before they got hold of it????????????? i am puzzled m8
W
whyte146
Couple of questions for you?
1) is there only 1 fan on your alloy rad, is it adequate?
2) what do you think of those mishimoto intercoolers?
I would appreciate your input.
Thanks
redevo
Im puzzled by your reply as it makes no sense?
Thanks
1 fan is fine, had same fan on my old 560bhp evo 7
mishimoto products i feel are good, i have a mishimoto radiator also.
mart1983
mart1983
what i was trying to say! did lee f*ck up your car? or was you disappointed because of the power? sorry i am thick and i can't type...... ffs lol
redevo
No he didnt F**k it up, it was just worse to drive imo to what it was prior, i expect it was down to the oil vapour going back into the system giving them a false reading, which is why im surprised they actually carried on and didnt just abandon doing it and put my original map back on.
redevo
Few more bits turned up.
Alcon 365mm brake kit
HEL full clutch and brake braided lines.
oil filter housing
Timing belt and pulleys
ACT clutch kit
Brand new TT S214B turbo
redevo
Engine built up as much as i want ready to fit in car tomorrow.
C-tech exhaust manifold.
Block painted, new oil filter and housing fitted.
Genuine mitsi flywheel and new bolts.
ACT 6 paddle clutch rated at 651lb ft.
Rebuilt evo 7 gearbox with 17k miles on, poly engine and gearbox mounts.
On the ramp for the morning.
Inside stripped out, evo 7 5 speed gear cables and lever, fuel pump hardwire loom being fitted.
