L
luke sheath
hey guys, im running the engine in on my evo 4 after rebuild (see my other thread) at the mo its only running actuator pressure ie the pipe on the bottom of the turbo is looped back to the actuator, its only at 7-8 p.s.i just thinking to myself once the engine is run in I would like to turn up the boost a little, ive owned 5 Nissan 200sx's and on those if you use a bleed valve you can go to 12p.s.i before you hit fuel cut problems,
is there a similar deal with the evo 4 ? I have a spare bren device bleed valve in the house, could I plumb that in?
what is the boost limit before you hit a fuel cut?
thanks again everyone!
luke!
luke!
