Coil plug connectors plz
B
bakes fq
Ok so I fitted a cop kit that was made up but dident have the connector plugs on the end , so I cut off the female connectors that were there and hard wired it in .. But now Iv orderd a sparktech coil set that has the oem plug in connectors but I haven't got the female connectors to plug it into anymore : ( . Does any1 know where I can pick to up from so I can wire them back in plz : )
I use these guy's mate!
Vehicle Wiring Products Ltd. Suppliers of auto electrical parts.
meka
meka
You mean the two male/female connections to hook up to factory harness right?
I got these identical connectors off older mazdas at the wreckers.
I think there was one per car clipped to a bracket on side of block. Pretty sure it's the O2 sensor connection.
B
bakes fq
Yeah that's what I need lol ill keep a look out . Thanx m8
B
bakes fq
Hello m8 : ) . Iv been searching the last 2 hours for what I need and the only place I seem to be able to get them is America and its working out $47 , that's crazy .. Ill have a look on that site now and see ; )
B
bakes fq
Need 2 of them , do u think ill be able to pick some up in this country lol
clutchitupson
clutchitupson
quick info,
You get them off Mazda crank sensor,and you can find them in the Mazda Lantis as well as the later 90s 323's,the plugs that fit to the evo loom can be found just behind the headlights in 323 Mazdas. 2 each side, later 90's model I think it was.
gona be worth a phone call to mazda tomorrow
B
bakes fq
Perfect . Ill give then a shout tomorow and see what they say . Thanx for the help m8 , will let u know how I got on ; )
