invisible
- Nottingham
Hi All,
For those that know me when I used to be a more active member and attended the odd show or 2 I took my Evo off the road about 15 months ago as had a few niggles and to be honest as other events took over and I started plodding around in my daily months passed very quickly!
Good news is I have finally decided to get the niggles sorted and bring it back out to play again.
Decided if you want a job doing properly you might as well pay the experts to do it quickly rather than me spending spare weekends for months on end scratching my head so its going into NR Autosports on Sat 20th April and they are going to have it for the week or two and do the following;
1. Full Service - All fluids + Belts (not due until next service but as it's been standing around and the car is old for it's low mileage worth doing now) + probably do plugs too.
2. Investigate the notchy 2nd and 5th gears (got a feeling this is going to be the expensive bit!). I'm hoping it's just fresh oil that's needed but not convinced.
3. Investigate whinning noise at speed (could be transfer box)
4. Check whistling noise (dump valve / Turbo)
5. Replace the exhanust manifold with a standard polished and ported one I have had sitting around for 2 years now! (Car still riding the cheap ebay one that came on it when I bought it and has cracks welded over)
6. Sort out problem with engine cooling fan (only the AC fan comes on at the moment when the engine gets hot)
7. Check if anything draining the battery as it tends to go flat quite quickly but that's probably more to do with me not using it)
8. Check the fuel pump+wiring as had the odd intermittent problem in past
9. Wire rear fog into reverse light so I can lose the one hanging down from rear bumper
10. MOT
I have set aside a few grand for this project. If the gearbox needs to come out and be rebuilt then a big slice of the budgets gone. If not and a more simple fix then I will lay out for them to remap it, set car up with fast road alignment and maybe see what else I can squeeze in.
I named my EVO 'Eleanor' after the Shelby in Gone in 60 seconds so I am sure they will find one or two other areas that need attention too but will see.
Will keep you posted and look forward to getting to a few meets over the coming 'summer' months
PS. I've still got the 8-man tent for the shows
10. MOT
