Gauges
Sy1000r
West Yorkshire
Looking to have some gauges fitted turbo, oil etc will it void my warranty? And can anyone recommend where in Yorkshire to have them done regards sy
Aidy
Aidy
Kent
It shouldn't, but obviously if you need to drill things to get the oil temp working and you have a problem with your oil tank after then your warranty company wouldn't cover that. Likewise if you drill holes in your manifold for an EGT. Boost gauges can be plumbed in with no damage though.
Sy1000r
West Yorkshire
Thanks for reply aidy have to have a rethink don't want to void warranty thanks again sy
Sy1000r
West Yorkshire
Any where in Yorkshire I can go for boost gauge fitting! And if I have to supply my own with pod anybody no where to get them from? Regards sy also looking to get rear doors and sides protected with a wrap any help appreciated thanks again sy
D
daryn
"Drill things to get oil temp to work"??
Sandwich plate? Or does later evo not have a plugged off branch in the filter housing for this?
That's what i done on my evo II
X
xiii
Try simon@nts on here for boost gauge fitting. Ive a pod for 52mm gauge if you need one. Good guy and knows his stuff. As for wrap im unsure whos good in the area. Google is best bet.
