Butterfly seals
DDS789
DDS789
South Yorkshire
Hi guys
Well had a slight missfire through the revs that has gradually appeared then disapeared over the last few weeks/drives. Think I've now sorted it though so :D
But during my fault finding I did a boost leak test with my compressor and boost leak kit. Found decent leaks, one from a reducer for the DV and one on the throttle body!
After some research I've worked out its the butterfly valve seals in the throttle body. I know this as when I turn the butterfly or wiggle the shaft the leak note changes in turn.
Anyone else had this? I can only find old posts with old links to where I can buy some new valves, all seem to be American too :confused:
some links to places to buy would be brill :awesome:
JakeMac
JakeMac
Bournemouth
Ive got a slight leak around my throttle body at the moment, I haven't done a boost pressure test yet but I can feel a leak with my hand from the top of gasket between throttle body to manifold so hoping its just that
I was doing some research on it the last week and theres a few threads on it over on the evolutionm forum, they mentioned it just being a rubber o ring which you can get from halfords or equivalent
I've got my gasket on order from camskill so just hoping I dont have to change the o ring on the butterfly but if you wanna take a few pics as you do it I'd really appreciate it in case I have to ;) :)
DDS789
DDS789
South Yorkshire
Will do buddy. My only fear is the throttle position sender, I may have to buy a volt meter to get that spot on.
Mine leaks out of the part where the shaft enters the throttle body, has a spring wrapped round it too.
Will be a bonus if that's where yours is leaking as that should be easy to fix!
You can also use evoscan to check throttle position sensor!!
raph
On the couch/ Germany
There isnt any cirrus series engine (yes all 4gxx are cirrus series) that dont have leaky throttle bodies.. dealer used to swap the complete assemblys on waranty. .. and thats why many dealers insist that there are no seals or BISS screws and o rings available separatley.
thanks for the rebuild link! good find!
JakeMac
JakeMac
Bournemouth
So dose that mean if I wanted to get them from a main dealer I would have to sit on the phone for half hour argueing with them lol! :)
JakeMac
JakeMac
Bournemouth
This might help
JakeMac
JakeMac
Bournemouth
Cool, thats got the voltage values in it, I couldnt find them in the workshop manual, dosent help trying to read it on my phone tho :)
DDS789
DDS789
South Yorkshire
I suppose doing a volt meter before taking it apart will be key then matching it after the rebuild :sneaky:
JakeMac
JakeMac
Bournemouth
Yeah I guess as long as you get roughly the same V value before and after then you should have it spot on.
I found in my vehicle history that it had a new TPS fitted by indigo a couple of years ago and has since been mapped, however it always idles at around 9-950rpm which I think is a bit high??? I'm gonna check mine tommorow but thinking about it :thinking: the high idle could be caused by the potential leak on the gasket
DDS789
DDS789
South Yorkshire
I would say that's a low idle mine idles at 1k easily. But I do have a leak so could be a similar issue :confused:
IV got to buy myself a multi meter now :razz:
