Bit of wiring help
McFall1984
McFall1984
Co. Tyrone
I'm baffled
Got this 60mm gauge here
Wiring is baffling
I'm stuck
Anyone any ideas were I'm to wire these?
McFall1984
McFall1984
Co. Tyrone
There's more than 3 wires lol
4 wires from the gauge
Red
Black
White
Yellow
2 to the sensor
Red
Black
3 from the sensor
Red
Black
White
But got it sorted for now
deanmac
deanmac
North Devon
the sensor wiring
red from sensor ------- +12v
white from sensor------red on centre plug on gauge
black on sensor--------black on centre plug on gauge
other 4 pin plug on gauge
red-------+12v
Black-----0v ground
the white and yellow change the colour of display by connecting them to 12v
McFall1984
McFall1984
Co. Tyrone
the sensor wiring
black on sensor--------red on centre plug on gauge
other plug on gauge
red-------+12v
Black-----0v ground
Trial fitted there
4 on the gauge
Red to +
Black to -
White to +
Yellow to +
White an yellow are for lights
Sensor wiring
Red to red on middle plug on gauge
Black to black middle plug on gauge
White left unplugged
It lite up but haven't got the sensor piped into the inlet yet
deanmac
deanmac
North Devon
just edited correct now
you have a clone defi gauge from china.
I have one here on my desk
deanmac
deanmac
North Devon
Trial fitted there
4 on the gauge
Red to +
Black to -
White to +
Yellow to +
Sensor wiring
the gauge will not go to zero or work when you have it wired like this. As there is no power going to sensor.
when you connect red sensor wire to +12v and white sensor wire to red and black to black.
The gauge will go to zero instead of -1
McFall1984
McFall1984
Co. Tyrone
So white goes to red to get it going?
We're as I had white plugged nowhere
McFall1984
McFall1984
Co. Tyrone
so can someone run through all the wiring so i can get this wired tomorrow
McFall1984
McFall1984
Co. Tyrone
aye but i mean wire for wire
ive this and an oil pressure gauge to wire
just wanna do it right 1st go lol
+ any were to fit the wires through the bulkhead?
McFall1984
McFall1984
Co. Tyrone
Ok wired the boost gauge up tonight there
Gauge
red to +
Black to -
Yellow to dimmer on radio
White to +
Red on sensor to +
Black on sensor to -
White on sensor in with red +
Gauge reading -1
When cars running it doesn't move from -1
I've tee'd into the hose coming from the front centre of the inlet, same one goes to the dump valve
Any help?
deanmac
deanmac
North Devon
Gauge
red to +
Black to -
White to +
Red on sensor to +
Gauge reading -1
Any help?
I did explain this several times in previous post
gauge will then go through opening ceremony and go to zero instead of -1
McFall1984
McFall1984
Co. Tyrone
yea sorry i worded that wrong
what i've done
4 wires on gauge itself ( red, black, yellow + white )
red to switched live ( red from radio )
black to -( radio again )
yellow to dimmer ( radio dimmer )
white to switched live ( again radio red )
red goes to sensor in engine bay
black goes to sensor engine bay
red connected to red from centre plug on gauge
black connected to black from centre plug on gauge
white connected to red ( tee'd into red on same gauge ) centre plug on gauge
McFall1984
McFall1984
Co. Tyrone
That is still not the same as I explained :shock:
look again:wtf:
So red in the sensor goes to a switched live
White goes into the red on centre plug
Black to black on centre plug?
Sorry matey I always thought its matched up to the colours
I'll give that ago when im at the Evo next
deanmac
deanmac
North Devon
Glad you got it in the end mate
