disable press clutch to start, Evo 7
christian3po
christian3po
Peterborough
Please help, How do you disable the "press clutch to start " on an evo 7 ? ive got used to opening the door, turning the key, going back inside for a coffee then driving. i don't really want to have to sit down before i turn the key therefore delaying my coffee. thanks.:)
Just disconnect it from the clutch pedal simple :)
There is a plug at the base of the pedal just unplug it, you can enable it at any point
Yh it's that simple pal. It literally just unplugs and it's disabled and you plug it back in to enable, I go through phases of wanting it and not so mines for ever changing, like of I'm working on the car I want to just reach in and switch on the car not get in with dirty overalls ect
