evo sst fq300 help plz
madmanc
madmanc
hello all hope u can help i have a fq300 evo x
right hear goes first thing wen i put in park it still rolls a bit fit i push the gear leaver forward its as if it whats to go in seconed thing is wen i slow down (take my foot off the pedal )to say 5mph there is a small clunk as if is droped out of gear if i put my foot back on the power is there and i cant seem to see any other probs changing gear as normal power all there think it only happens wen car is warm will cheq next time im out in it tonight
Automatics don't really have a clutch as such like a manual box does!
It's not an automatic :) It actually has two clutches and proper gears. It's basically a manual box without lag.
Arrrrr sorry Aidy! Are they the same as the DSG box then?
madmanc
madmanc
So do we think its the clutch ?? It's changing gear fine it's only say wen I'm in ttafic rollin if I use my brake to stop it don't do it but if I'm just rollin after foot on pedal about 5 mph it's a. Small clunk
madmanc
madmanc
so do u think i need a whole new clutch? if so dose anyone know where i can get this done round yorkshire ?????? and how much u think im lookin at ???
Aidy
Aidy
I don't know what it could be TBH, it doesn't stand out as a clutch issue but I'm no expert with this box. You probably need to take it to a specialist near you to see what they think. The problem with these things is that even the investigation can be hours of labour unless someone has seen the issue before and knows what it is.
madmanc
madmanc
thanks will do that hope its not that bad only had it 2 months :sad:
Aidy
Aidy
If you got it from a Mitsi dealer I'd take it back there.
R3BB
That's one of the hardest posts to read I've seen! :wtf:
If you've only had it 2 months, get it back to the dealer you bought it from.
Whatever is wrong with it, it shouldn't roll in 'park'.
Mattrst
How many miles is on the car and has the SST fluid ever been changed?
madmanc
madmanc
its got 44000 and i dont know i goin to take it in for a full service i think to get it all cheqed over
Mattrst
From what you see on the US forums, the service schedule on the SST is miles out, might be worth a shot for a couple of hundred notes
