Stutter on boost :/
stevenc8084
Hey, my evo has a stutter moment when on boost. Its at around 4 - 5000 rpm. It jerks violently hard, just changed the plugs as a starter, BPR8ES, didn't adjust the gap as I don't have the tools. Is the standard gap fine? Its a evo 6, probably around 300 BHP. Still doing the stutter after the plug change, plug leads next?
mattyb26
mattyb26
Gaps should be ok they ain't usually that far out
stevenc8084
Its a hard jerk which throws you forward, I then come off the boost at that point......
Mikeyc
Mikeyc
Worthing, West Sussex
Throws you forward? Yeah look at the mounts first to see if the engine is moving, do you know if the jerk is coming from the movement of the engine which then throws you causing you to come off the throttle or is it actually the engine itself
stevenc8084
Yeah throws you forward, I would say its the engine itself as the boost is building to its peak
Aidy
Aidy
Kent
Sounds more like a fuel cut. Are you using the standard actuator? They don't last very long on VIs due to there being no protection from the elements. Do you have a boost gauge fitted?
stevenc8084
I think its standard, only had the car a few days, previous owner didn't mention anything. And yeah there a boost gauge its a cheapie though. Its got a electronic boost controller too, can this have an effect?
Aidy
Aidy
Kent
What does the boost go up to when it happens? Is it about 1.2/1.3?
stevenc8084
No idea, won't be able update a figure till the morning too. I will update soon as, and il check the mounts but it definitely feels like a boost problem with the engine.
stevenc8084
Ok, boost goes to 15 psi according to the gauge, holds there once spooled up but that's when the kick back comes in. Any ideas? Seems to be running a touch better since changed plugs.
deanmac
deanmac
North Devon
I thought plug gaps should be about 0.55mm which is a lot smaller than they normally come set.
I put new plugs in the other day and had to close gap quite a lot.
Aidy
Aidy
Kent
It's not likely to be fuel cut at that boost. You really have to start with the basics and get the spark gaps checked, as even being fractionally out can cause stuttering under boost.
stevenc8084
Ok, the gauge showed it spool up to 15 psi peak, where it then threw in its problem. It does seem to run a little better after the plug change though. Any ideas???
stevenc8084
Sorry, written that twice :/ ok I will try and get a exact gap with the plugs. Will update soon, thank you for the input guys.
C
Chris@epp
Hampshire
Might be worth finding a mapper/geekmapper and having them log when it happens.
Is it on WOT, or are you slightly off WOT? Is it 3rd and 4th gear?
Where abouts are you - I am sure there will be someone around who can give you a hand.
stevenc8084
Iv ordered myself a spark plug gap adjuster. Il start with the 0.55mm as stated, as I have read most have set at this. Fingers crossed, if not then I may seek a mapper. Does it in 2nd and 3rd, not really took it through the other gears as not been on any long enough roads. I'm from Rotherham. As i say its much better since the plug change so im hoping closing the gap up on the plugs may fix this, its a big hope lol. Will update when i have tried this, thanks guys.
X
xiii
Apologies to the op but it sounds like my e8 although mine isnt violent and it only sometimes flutters on boost. i thought it was a crappy dv. il check my plug gaps tomorrow. cheers for the tip.
