You need to remove the cross shaft on the nearside of the gearbox you will need a sliding hammer with a M8x1.25 bolt on
That was the next resort. To take the whole clutch assembly off. Should the thrust bearing separate easily from the plate?
Yes they do you need to pull the clutch fork toward the engine as you put a screwdriver between the bearing and the retainer clip then twist the driver and it should release
ah, you make it sound so easy Jamie![]()
i can thrid that one i was surpriced how quick it took we me and my mate
