evo_4_macky
Hi Guys,
Im macky, i have a mitsu evo 4 i purchased recently , and im also a newbie to this forum so your help much be greatly appreciatted,:razz:
anyway i bought my mitsu evo 4 before xmas as a non runner,
after looking into the engine and my diagnosis , i found that it needed a full rebuild,
on stripping the engine, i found the following faults,
balance shaft belt snapped,
cam belt, 5 teeth missing arround the crankshaft,
the seats that the cams sit in in the head was scorched,
4 valves bent,
and only 3 shells out of 8 left in the big end,
so therefore in my terms it would be what i call F****d
anyhow, this is where you help, advice, knowledge may help me,
i sourced a 2nd hand block, (complete)
and also a 2nd hand head (complete)
obviously i have been through the nessercery procedures to rebuild the engine .
all has been sweet and i was on my first testrun after fully rebuilding a new engine, since bringing the car home as i was pulling back into my garage the oil light came on,
after looking into it a bit ive noticed that the dip stick keeps blowing out of the pipe and spraying oil everywhere, ive been out a few times and it keeps happening, now since trying the car on a test run the oil light is now staying on permantly on idle, and i have a rattle/tap coming from the engine however when i rev the engine abova 1100rpm the light goes out and the rattle goes,
ive tried the ops ( oil pressure sensor)
i havent as yet done a oil pressure test, as i awaiting the tool to come,
however you help would be greatly appreciatted as to the best of my knowledge i seem to think the oil pump is on the way out,
however after being in the trade for 8 years, i have never experinced a oil pump failing as yet,
many thanks macky
4 valves bent,
many thanks macky
