9 turbo on an 8
izibecoz
izibecoz
Hey Guys,
Is it worth putting a 9 turbo into my 8 MR?
Have one spare and just wondered if its worth dumping in.
the 8 has 3" straight through and decat exhaust,Up rated fuel pump etc
Just had nice service, brakes, fluids changed, and new shiny plugs
Boost controller going in, and then a re map.. but before the map - wondered if a 9 turbo is worth doing or not, seeing as its spare?
Its an 8 MR320
C
evoaps
evoaps
ps my mate is looking for a 9 80 series or an 8 mr turbo so if you are selling either let me know :D
izibecoz
izibecoz
No idea what series! If its worth changing I will put on my MR, and then sell mine.
Only done 32k miles in the 8MR
evoaps
evoaps
look at the 9 turbo if the numbers start with 01380 then its worth changing :D
izibecoz
izibecoz
So if it is an 80 series then why is it worth swapping? Better internals?
Bare in mind that you'll also need the j pipe and oil return line from the 9, to fit the 80 series to your 8
9 turbo is better end of. It's bigger too so will give better power at lower boost.
You will need a evo 9 j pipe to fit mind, or a hks evo 9 j pipe. If you mr has the hks hard pipe kit you will need a reducer to fit the j pipe to the lower if pipe..
Billy MR
Billy MR
Dirty matt pictures :D
Of what :shock:;)
Billy you have a pm about one heat shield and vent ;)
