Fault code check now abs light on??
dan2926
dan2926
Wondering if anyone would have any idea what the problem could be. My ayc light was coming on so i bridged pins 1+4 and checked for fault codes which i got 41 and 82 :(.
Now the car hasnt moved since it has only been washed. Now when i turn the ignition on the abs light is on and doesnt go out it wasnt on before and never has been. Could it be related to checking the codes or could it be coincidence. Car sits for around a week at time.
Wingnut247
Wingnut247
82 is pump fail! Rebuild required or new pump! I had the same codes when mine went! Can't remember wat 41 is but I had abs light on too! Replaced pump and both lights went out!
Clear the codes by disconnecting the battery for 10 mins then re check the codes.
dan2926
dan2926
Yeah mate im looking into repairing the pump. I was just wondering why the abs has also came on now as it wasnt on before, she is booked in at wallace performance in dec so hopefully get her sorted out then.
