When diffs go bad!
Carbon
Carbon
My rear diff died a couple of weeks ago so between bouts of grinding, sand blasting and welding on a beetle I decided to strip it and see what went wrong.
This doesn't look encouraging!
This side is ok.
As is this bit
Oh dear.....
I'm sure these bits aren't meant to be that shape!
Oh, I wonder where that came from?
That could be it!
Casing damage too - unsurprisingly.
Not much salvageable there then :lol:
madmilligan
madmilligan
Shit is it ayc? looks fooked only takes one piece of gear to fook the lot up :( mines due all transmission oil changing so best get it done !!! Hope you find a cheap replacment!
Carbon
Carbon
I did indeed. Had the car back on the road the same week. I just took this one apart to see if I could salvage anything :)
The AYC bit is the bit that's fine!
Least you got the satisfaction of opening it up and seeing a satisfying mess :)
coolamasta
coolamasta
Ouch, yeah I got pics like that as I've killed 2 AYC diff's to date, the first one I cracked the outer casing so bad some of it fell off!
