Cannot Engage Gear
J3ayy
J3ayy
Malton, North Yorkshire
Took the evo out for a drive yesterday & noticed that i had to push the clutch further down to engage gear,which started to get worst i pulled up to a junction & selected 1st & still had the clutch pressed & the car still wanted to drive luckily there was no cars so i managed to get on the main road the only gear i could select was 4th , i limped home in 4th gear Now if i starts the car & try to select ANY gear it wont engage,but will if the car isnt started. I had a ACT prolite flywheel & clutch 2 years ago & only covered 5000 miles.
ANY IDEAS :confused:
rob@indigo-gt
If you pump the clutch about 10 times, then does the gear change get any easier?
If so, may be a hydraulic problem (master or slave) Give it a good bleed and see if it makes a difference.
If not It may be a clutch problem :(
