Guess the power
Spoonz
Hey all,
Car is of to FCM this afternoon for a nice re map so what you think the power will be
Mods - EVO 7
S/S Manifold
Decat and full exhaust
Bigger FMIC adn Pipework
K n N air filter
Greedy Profec Spec B
Walbro Fuel Pump
Helix Paddle Clutch
Helix Lightweight flywheel
Running 1.7bar
Spoonz
will have to wait a few more days appernetly some problems with fueling :(
drue1
drue1
next to my wife
0/0 at the mo.everything will get sorted fella and when it does you will love it and wont more.i started at stage one and now 8-9k later its a 2.3 gtx3076 hoping for my 500/500 and still a long list of bits to do
I guess no power then ;) any news on this mate?
Spoonz
apperently there is a fueling issue the car is running lean?
check pump maf fuel relay and still no answers :(
Bristol
yeah sorry this is taking long than expected.... so much for a simple remap :(
with the air leaks solved we thought it was going to go well but ...
The problem seems to be something with the fuelling, as is doesn't seem to want to get lower afr's than 13.5 which isn't good, first we found that the standard high voltage relay had been cut so thought it wasn't getting the 12V supply and just the 8v one but that wasn't it, checked the fuel filter and pump swapped out with a known working one no joy, swapped out fpr no joy, swapped out injectors no joy, checked all pressure lines to fpr, checked the fuel lines to see if any had been crushed they looked ok, so next thing it to check the wiring.
As we're checking things bit by bit to find out why its doing what its doing its a slow process. Will keep you posted
Andy
Spoonz
Wasn't a dig btw if it look liked it was just saying what I was told
Bristol
hi I didn't think it was a dig, just wasn't sure how much info you'd been told, so thought I'd try and update you, hopefully it'll be sorted soon
Andy
invisible
invisible
Nottingham
FIngers crossed for you.
Sure it will get sorted.
My guess would be around 382bhp.
But really numbers are irrelevant its how the map is set up and the car drives.
Higher bhp doesnt necessarily mean a quicker car to drive.
I have a graph from mycar showing 391 but the graph is terrible, its clear they were just playing silly buggers on the dyno!!
ANdy will sort you out and get a nice map I am sure
East Yorkshire & Midlands
Andy
What load is it hitting andy at full boost just out of curiosity :)
