AYC Fluid force bleed "How To"?
B
B17BAP
Just wondering if someone can point me in the direction of a "How To" on force bleeding the AYC myself as I've searched and had no luck other than finding posts mentioning it.
Also is it recommended? I've read loads of people saying you should never do it yourself without the MUTII tool? If so I'll just take it along to Extreme Motorsport and have them do it once I've done the Diff, Gear& Transfer and Clutch fluid myself.
Thanks in Advance for any help
B
B17BAP
Found some info on it and I'm not sure I'm keen on being under a running car with the wheels moving on axel stands, so probably just take it along to extreme.
Force bleed?? Is this like a normal bleed? Wouldn't it be the same as the front transfer box, ignition on loud pedal all the way down with nipple open and out it comes
That's the way to do it :)
B
B17BAP
Yeah that's what I've read you need to do for a evo IV for the rear AYC, not sure how much I trust myself doing that lol Extreme aren't too badly price anyway
Sometimes things like that are best left to experts if your unsure yourself :)
I was "told" by a reputable trader that just cracking off the bleed nipples and letting it gravity feed does the trick, how true pass, but from a trader I would use
I was also told holding the brake and throttle down fully then switching on ignition runs the pump for a few seconds, again how true, if someone could confirm
Ignition then throttle will activate pump and enable you to bleed transfer box on 7/8/9 but not rear diffs on any model
trackday
trackday
did my 4 by wheels spinning way but on a two post ramp was still hairy though wouldnt like to do it on axle stands lol but to be fair it did work :)
