So, Boost leak detection
Carbon
Carbon
Newton Abbot, Devon
I appear York have developed a boost leak. I'm suddenly only making 1.3 bar instead of 1.5 and there is a whine/buzz like when you blow a blade of grass but higher pitched. In addition to this I've started to get a "chirp" when changing gears. Oh and I have an EBC.
So, how do I find it easily? Any tips/common locations to try?
Evo4TomB
Evo4TomB
Tewkesbury
Dump valve is a good start ;)
Is it a high pitch squeal when you come on boost ??
Check the condition of the turbo as well , mainly check the play in the shaft a little up and down is ok .5mm but in and out is a big NO ;)
Carbon
Carbon
Newton Abbot, Devon
It is a high pitched squeal. Not terribly loud but noticeable. Aggressive gear changed and acceleration cause the chirp.
The dump valve is an HKS SSQV - I think anyway :lol:
East Yorkshire & Midlands
Only real way is remove the hose off the turbo j pipe and block it off, then remove hose off throttle body and make pipe work incorporating a shrader valve (tyre valve) and use compressed air to pressurise the system at 15 psi and listen for leaks
Carbon
Carbon
Newton Abbot, Devon
That's doable. I'll work something out with some compressor fittings rather than a schrader valve so I can keep it topped up to 15psi and go at it with some soapy water.
Cheers for the tips guys :)
Yes I use metal pipe that fits nicely in the hose weld a top on the metal pipe, then drill it and pull through a rubber car tyre valve, works a treat
Carbon
Carbon
Newton Abbot, Devon
Cool - I have a feeling it may be the dump valve anyway so I'll check that first. I also want to replace it with a decent recirc one at some point for a more stealthy sound :ninja:
Carbon
Carbon
Newton Abbot, Devon
I've been busy so haven't had chance to make a pipe up yet to test for leaks. I have stripped, cleaned and refitted all the pipes but it's still only making about 1.3 bar. I've checked the turbo for play and all is good there. I've tried adjusting the ssqv a touch (it's an early one with adjuster bolt) and that seems to have made no difference. The car has also started making a clanking that doesn't seem yo be related to the twin plate clutch for once. It only does it when rolling so I guess it's driveshafts, gearbox or diff. Off to the garage as soon as I can book an appointment!
DDS789
DDS789
South Yorkshire
Get one of these bought off the bay
160832945444 :)
Iv got one and it does the job great, tried it on my old scoob and you wouldn't believe the amount of tiny leaks I found that equated to the boost loss I was suffering :shock:
Carbon
Carbon
Newton Abbot, Devon
160832945444 :)
Ideal. Expensive compared to making your own but when time is of the essence.......
Ordered :)
Now I just need to find the clunking!
DDS789
DDS789
South Yorkshire
Expense vs hassle of making your own, was what I thought lol.
I also watched a lot of YouTube vids about detecting boost leaks and using something like these kits. Just so you know what noises to expect and stuff.
Cool thing with the kit is you can isolate areas, as in block off say the intercooler pipe into the throttle body and then stick the kit on the turbo and purely check your intercooler pipes.
Then you could check throttle body through the engine, that's how you would find vacuum pipe leaks, but there will be different noises to contend with as the air leaks through the engine etc so watching the vids is a good idea to know what to expect.
From what I remember the icv pipe will need blocking too.
HTH
Dan
L
Leroy
rushden, northants
i made one quickly and it didnt last long so bought one off ebay, u should hear all the lil leaks its surprising really
Carbon
Carbon
Newton Abbot, Devon
Bugger. My boost leak tester is massively larger diameter than my intake pipe! I'll have to bodge something together anyway :(
Carbon
Carbon
Newton Abbot, Devon
Well, while I wait for my reducer pipe to turn up I've had another fiddle (ooh-errr missus) and found the sad pipe is disintegrating so that is probably some of the problem. In addition to this the clanking noise has gone away so I haven't killed my transfer box which is nice :lol:
Now all I need is my wheels to turn up undamaged this time!
DDS789
DDS789
South Yorkshire
I got a load of different pipes with mine all different sizes. The valve and pressure gauge was probably 50mm wide so could even take it out and put it directly into piping.
Best bet is attaching the leak kit directly onto the turbo. Remember to block off pipes that direct back into the intake too.
Carbon
Carbon
Newton Abbot, Devon
That was the original plan - however the turbo input on the V is 56mm and the tester fits 76-85mm. Only the one pipe so I need to bodge something together with reducers - the intake pipe was my 2nd plan but that's no nearer in size :eek:
