PMoreland
Hi,
I've been having some problems with my Evo 6, it stuttered at a roundabout the other night then once I'd got back and parked up, it wouldn't start the morning after. It cranks but no start, no engine light is showing.
I've tried multiple engine OBD II scanners but can't seem to connect to the ECU, the bridging pins didn't work either. After checking with the multimeter there's ignition power to the coils and they seem to measure fine on resistance but no spark is being generated. I've been trying to diagnose and check the crank sensor, I can't seem to measure any resistance or voltage through the sensor so I'm making an assumption that this may be the cause of failure ???
I've stripped it down and the sensor seems all intact and without any visible damage. Has anyone tried to measure voltage through their sensor with any luck ? I'm trying +ve on red and both the blue and black as -ve connectors while cranking but no reading is measured. I want to be sure the sensors gone as funds are tight after only buying the car a few weeks ago.
Finally, I'm not sure if this is part of the problem but my Tein EDFC unit isn't showing any display when the ignition is on any more. It's in line fused to the ignition which hasn't blown, neither has the main ignition fuse blown. There is power to it but no display, surely it should come on when the ignition is on?
This cars beginning to stress me out
