Brake pad bedding in help.
gooner8
gooner8
hi all. After getting bembo's fitted yesterday with new the disc's and pads. Pads are oem bembo's. Not bedded in yet as only done about 60 miles with them of light braking but starting to get bad judder will this go once i start giving them some stick? Also on the bedding in details its said to go to the owners manal and follow those details! My 4 never come with one lol so any help with this would be great. Thanks Nick.:)
Steveyb_evo3
Steveyb_evo3
just gently braking for a few hundred miles should be fine but all depends what pad your using i know the carbotec pads come with the instructions with them
you shouldnt be getting judder on bedding in
gooner8
gooner8
surely it won't be the disc's ? Didn't happen at first just seems to be getting worst. I'll go out in a bit put some more miles on them. Cheers Steve.
gooner8
gooner8
yeah they kintek disc's came in the right box etc dimple and groved?
Steveyb_evo3
Steveyb_evo3
Maby u just got a naff disc give it a hundred miles or so and see how it goes try not to put to much heat in them while bedding in do they vibrate all the time? Or just when braking
It's not something silly like there so close to the wheel they have taken off a wheel weight?
gooner8
gooner8
seem's to be getting better? Done 80 miles now and have done loads of light braking! Like you said i guess time will only tell! Only does it when braking didn't do it at first? :)
STEVOVIII
STEVOVIII
They should be fine after about 400 miles or so of gentle braking. After that; give them a squeeze now and again. The shudder should diminish over time.
gooner8
gooner8
were they cheap nick ?
not the cheapest! But yeah :eek: look ok tho! Seem's to go the harder you push the pedal? And does feel like its getting better! Just want to give death lol see want they like? :)
