Boot badges carbon
LeeEvoMR9
LeeEvoMR9
Any one no were I can get in carbon evolution with IX as well bin looking and find a few all in us tho 
LeeEvoMR9
LeeEvoMR9
Good old b6lee any d1 wheel nuts as you looking lol
Something we have been working on with the help of Evogeof, he will be receiving a full kit this week
You can have any configuration of the FQ numbers you like eg: 340, 350, 390 and so forth.
(1) 2x front door decals eg: "FG-340" in carbon or any colour vinyl (any number you like)
(2) 1x rear boot as above
(3) 1x rear boot decal "Lancer" in carbon or any colour vinyl
(4) 1x rear boot decal eg: "EVOLUTION IX" in carbon or any colour vinyl (please specify which model required)
(5) 1x rear boot "mitsi diamond" in carbon or any colour vinyl
(6) 1x front "mitsi diamond" in carbon or any colour vinyl NO doming on this due to fitment (waiting on a size guide for this logo)
(7) MR Badge in RED is also available
Standard flat cut carbon fibre effect laminated vinyl lettering.
(1) £4.00 each (2x reqd)
(2) £4.00 each
(3) £4.00 each
(4) £12.50 each
(5) £4.50 each
(6) £4.50 each
(7) £4.00 each
If a VINYL DOMED kit is required the prices are as below individually:
(1) £7.00 each (2x reqd)
(2) £7.00 each
(3) £5.50 each
(4) £21.00 each
(5) £6.00 each
(6) £4.50 but as above no doming due to fitment
(7) £6.00 each as an optional extra
Domed and decal application - PLEASE NOTE:
These logos are all self adhesive but due to the time of year I would suggest the following as regular transfer tape will not pick these up very well due to the doming compound plus leaving the transfer tape on them for a long period of time may leave an impression on the doming.
Letters will come as seen in the pictures below.
Clean, degrease surface area for new decals.
Mark a line with masking tape for your new decal.
Apply a few layers of masking tape to the whole decal so it can be applied in one or two hits, this will ensure it is applied all pre-spaced as it is supplied on the sheet.
Once the decal has been lifted from the backing paper it would be advised to warm the glue on the rear of the domed decals with a hairdryer (warm them well as they will start to cool very quickly) to allow the best bond possible or place on a warm (not boiling hot) radiator for a few minutes prior to application, do not overheat, this is just to liven up the adhesive and it can become lazy in cold conditions.
If you try to apply the decals cold or bend them when they are cold the clear dome can seperate from the self adhesive vinyl, this will happen as the clear dome is not as flexible as the vinyl, if they are warm then the decals will conform to your panels easier and they will not seperate from eachother.
Apply the decals to the vehicle using your guide line and rub gently over the entire decal, usually from the centre out.
Peel the masking tape off of the domed decals, pulling back on itself, if you pull the masking tape off in the wrong durection (at 90 degrees to the letters) you could potentially pull the decals from the car if not applied correctly.
Once the tape is removed push on each letter to make sure there is a good bond from the inside out.
Job done :)
If you do not apply them properly or try and stick them onto a greasy surface or try and apply them in sub-zero conditions they will not adhere properly.
If applied correctly they will apply easily and last.
I would not advise a pressure washer directly onto the domed decals though, the original tommi decals have been on my evo for 10yrs and the Mitsi valeter managed to jet wash my door decal right off the car a few years back!
Cheers,
Lee@fcm
(-: ALL ITEMS ARE ON AN INTRODUCTORY OFFER :)
And lee is the man that done all the vinyl on my car :)
No worries lee !
I'll be tapping lee up for a drink don't you worry :):)
craig@dd
craig@dd
me too i have these in carbon on the rear doors of my evo 6 look sweet lee@fcm top banana
