Ran out of fuel!!!
garriock_1
garriock_1
Shetland
The other night i made the mistake of thinkin i had enough fuel to go on a short run in my evo 6. then it started spluttering and cut out! I got some fuel put in it and it spluttered to the pumps. Then when I went to leave the pumps it wouldnt start! it offerd to a few times but still no luck! If any one has any ideas on what it could be id be much appreciated!
garriock_1
garriock_1
Shetland
When its turning over there is a smell of fuel from the exhaust.
garriock_1
garriock_1
Shetland
it had new plugs and leeds last summer. Iv not checked the coil packs.
EVOIV MJC
EVOIV MJC
N.IRELAND
take plugs out clean them and away you go,, there could be some fuel/moisture on the plugs??
liffy16
liffy16
oswestry shropshire
ran my 6 low on fuel light was for about 15 mile,filled up and car was surging on tickover
try resetting ecu (battery disconnect)it fixed my problem
Mid Wales
as said you've probably just wet the plugs so give them a clean and try again or just give it a bump start as that will probably be enough to get it going again (don't bump start if you are still running a cat).
Moray, 57N
Don't bump start an evo, you'll knacker it.
It's flooded spark plugs, remove them and heat them up :) I put mine on a gas hob for a few minutes, replaced them and it started first time
Mid Wales
lol, don't be silly, bump start is fine.
