roynx79
hi silly question will only the brembos of the e5 onwards fit theevo range???
brembos for evo 5-9 are all the same yea![]()
if you mean brembos from a scoob then no. although they are effect the same caliper to look at they are different offset, ie the distance from the cut out for the disc to the mounting face where the bolts go through are set out differentlyi mean brembos of other motors lee sorry prob should of worded it better
if you mean brembos from a scoob then no. although they are effect the same caliper to look at they are different offset, ie the distance from the cut out for the disc to the mounting face where the bolts go through are set out differently![]()
