Trickle charger help
STU3YP
KENT
Hi guys,
I have just bought an evo 8, and reverse it into my garage. I would like to keep it on trickle charge, ideally with the charger connection going into the boot.
Has anyone run a 12v connection into the boot that gave give some advice or pics?
Thanks in advance
Stuart
STU3YP
KENT
So I have now sorted this. I connected a fused 16awg wire to the battery and ran it through the engine bay, down the drivers side and through the Grommet into the driver footwell.
I then ran the wire along the floor under the scuff panels, up under the rear seat and into the boot.
I then connected a trickle charger adapter to it and ground in the boot. Works perfectly and allows the boot to be secured with the charger wire outside.
