timing kit help
DsmEvo
DsmEvo
Aruba
Hi all,
Would an timing kit from evo 8/9 fit my evo5?
Including:
- Idler Pulley
- Tensioner Pulley
- Balancer Pulley
- Tensioner
- Balance Belt
- Timing Belt
- Water Pump, Gasket & O-Ring
Only reason am asking is due to my location the 8/9 kit would be easier/cheaper to get.
Thanks!
liffy16
liffy16
oswestry shropshire
Don't think so no just get timing kit for your Mark I.e.5 or maybe 6 later engines are different obviously that's the evolution.sure el or si will make this a lot clearer
DsmEvo
DsmEvo
Aruba
Thanks for your input, yeah hope some1 can clear this for me.. my guess is that the belts stay the same is the other parts that im not so sure
Bristol
they are pretty much the same except the tensioner is slightly different
Yes. Same kit. But you won't need the tensioner unless it looks shagged same as the pulleys too
Billy MR
Billy MR
Norwich
Why not just buy the proper one for your car?
Ross sport sells them at a mega price :)
True, but if they are available, they should be changed, regardless of condition, otherwise it's time / money / hassle if required later on down the line.....
He's probably found it on the cheap.
DsmEvo
DsmEvo
Aruba
As stated due to my location, google Aruba then you'll get
why
If it's the same kit I would save allot on shipping being as in the states I get free shipping compared to ordering from the UK.
DsmEvo
DsmEvo
Aruba
Thanks, this was the answer I was looking for. Even though tensioner is slightly different as stated it will fit right?
Thanks in advance!
Thanks in advance!
To me they look the same. The Lilly on the tensioner gets replaced not the arm it's self, from memory they are nearly 200 quid. I done my belts and just done the belts, all other parts were more than serviceable
DsmEvo
DsmEvo
Aruba
Cheers bro!!
