but for that u will need a 3port boost solenoid or boost controller also a re-map induction kit and walbro pump
if your looking at more u will need cams cam pulleys and possible turbo change not sure tho but defo cams will need changing 272`s or something like that
I think 400 would be on the edge of reliability. I know some people have gone over (not by much),even on the earlier models and never had an issue, but then again, some people do have problems.
Personally, I think 400 would be my limit, but I have a feeling every time I wanted to push it a bit, I would be waiting for a major failure.
Are you thinking of pushing up to that power on a standard engine?
It probably would take 400 but there is no point maxxing it out with a chance of throwing a rod when he is forging in a few months. Will save the cost on a block and possibly head for the sake of a few months
That isn't possible and who bolted that turbo to a standard engine :shock::shock::shock::wtf::wtf:
I'd run that turbo a about 1:20 bar boost cos if you turn it up the your engine will shit itself. That turbo is good for 500bhp which is a whole lot more that your engine can take
you can up the boost as the revs rise which would help keep the torque down but I wouldn't bother running that turbo on the standard engine.
you can only tickle that turbo on the standard engine to keep it safe so unless you fit uprated rods you'd probably be better off with the faster spooling standard turbo.
.....or just tune it up as it is and tense your buttcheeks everytime you floor it
