Rear noise since ayc pump change on x
W
Who45
Mainly under load, straight line and sometimes on a turn, very intermittant, not every time..... Ayc rebleed do you guys think???? as its just had a new pump fitted and has been bled via the mitsi software.
Everything was fine before the new pump was fitted,old pump was not working for 2 weeks only after it failed.
More of a squark than a grind or do i need the oil for the clutch plates/bath oil in the diff changing?
Also made the squark on a heavy brake too. The only change on the car has been ayc pump.....input appreciated
