Possible gaind
jimdon
Hull
Hi just looking for tech info I got evo 8 just getting walbro 255 injectors and rail with 20g turbo fitted stainless steel man and pipe with excedy racing clutch fitted what possible gains can I expect on a remapping
jimdon
Hull
750cc plus forgot about the air induction aswell as above
mister H
Cheshire
You didn’t say which Evo8, Since you have standard cams, you didn’t need bigger injectors (IMO) you need to decide how hard you want to boost, safe boost of say1.6bar should get you a safe 360 bhp pushing boost further will take you up higher, your Turbo set up will allow 2bar easy but you could be in for an expensive bill, a safe 360bhp car is very quick, safe and reliable. Don’t forget to think about a better oil cooler too.
Good luck
jimdon
Hull
Its an 8gsr and going for some kelforf 272 cams any oil cooler you recommend??
