Performance Friction RH665 BRake Fluid
grant620
grant620
Introducing RH665 brake fluid from Performance Friction:
RH665 is not the same as other Racing Brake Fluids, it has been specially formulated for racing applications, where braking systems operate at very high temperatures.
It is a complex mixture of Glycol Ether Borate Esters and Polyalkylene Glycol Ethers together with advanced corrosion inhibitors, antioxidants and other modifiers. The result is an exceptional brake fluid with not only a very high boiling point but which also conforms to FMVSS 116 DOT 4 and maintains its class leading viscosity, lubricity and compressibility performance at extreme temperatures to ensure braking system reliability and performance and a
Rock Hard pedal.
RH665 has the highest guaranted minimum Dry Boiling Point (ERBP) of any DOT 4 Brake Fluid, 325oC, to guard against vapor lock and give a Rock Hard pedal even under extreme racing conditions. Many manufacturers quote “Typical” boiling points – do not be deceived, this is not the minimum specification that you could receive, it can be the result of a test on a single sample. “Typical” values for RH665 are invariably higher than 325oC. A similar situation applies to “Wet” Boiling Point, RH665 is guaranted to be above 195oC “typical” values are much higher and at least the equal of other leading brands.
Boiling Point is of course not the whole story, with Brake Fluid it is essential to have the correct balance of properties to get a good overall result. Low Viscosity is very important to ensure a good bleed, low Compressibility is essential for a firm pedal and Lubricity is vitally important for efficiency,
pedal return and life of the brake system.
Beware: Many Racing Brake Fluids do not meet the Viscosity requirements of DOT4. RH665 Racing Brake Fluid conforms to and exceeds all aspects of the U.S. FMVSS 116 DOT 4 specification. This means that it is has been tested and is compatible with all the rubbers (SBR, EPDM etc) and metals commonly used in brake systems and will not damage them. It also means, of course, that RH665 is entirely street legal.
Available in 500ml bottles at £21 inc vat per bottle.
Buy 3 bottles and get free carriage.
Buy 10 bottles, get one free AND free carriage!
