Ohlins Road and Track DFV Coilover kits from GB Enterprises
grant620
grant620
Somerset, UK
Hi Guys,
We are pleased to announce that we are now supplying the amazing Öhlins Road and Track Coilover kits!
Road&Track by Öhlins
This is the latest step in the Öhlins Racing automotive philosophy – Road&Track by Öhlins.
A more than 30 years long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street cars all over the world.
The focus has been clear from the very beginning – superior road handling without sacrificing comfort in your day-to-day transport. The time of compromises are over!
Öhlins has also added a clever light-weight design with a majority of the parts in aluminium and on top of that all shocks have gone through vast corrosion tests according to ISO 9227. The end result is a 2-year limited warranty on all of their R&T products - worldwide.
DFV Tech page Clicky
EVO IX / 9 Tech Spec:
General Features
◦◦ DFV (Dual Flow Valve)
◦◦ Rebuildable
◦◦ Corrosion salt spray tested (ISO 9227)
◦◦ 2 year Limited Warranty
Front
McPherson Strut
◦◦ Top mounts with camber adjustments
◦◦ Height adjuster (approx. 15 mm lower than standard)
◦◦ Spring preload adjuster
◦◦ Single bleed adjuster
◦◦ Coil Springs (rate 100N/mm)
◦◦ Dustcovers
Rear Features
Conventional Shock Absorber
◦◦ Top mounts
◦◦ Height adjuster
◦◦ Length adjuster (approx. 15 mm lower than standard)
◦◦ Coil Springs (rate 80N/mm)
EVO X / 10 Tech Spec:
General Features
◦◦ Rebuildable
Front
McPherson Strut
◦◦ Dustcovers
Rear
◦◦ Top mounts
◦◦ Height adjuster
◦◦ Coil Springs (rate 70N/mm)
◦◦ Dustcovers
Stock available NOW for:
EVO IX / EVO 9 at £2399.00 inc VAT
EVO X / EVO 10 at £2579.00 inc VAT
