Need urgent help
Evo4TomB
Evo4TomB
Tewkesbury
I'm in the middle of taking the transfer box out :wtf:
I have removed cross member and at the 6 securing bolts holding box to box
3 top and 3 bottom the transfer box has begun to slide off gradually but now is stuck so I'm :confused: it's not catching on the chassis or anything
Do I have to split the transfer box and diff side to get off the car :confused:
Please help guys as the bloke is coming to pick up 2moro morning :razz:
You need to pull the output shafts out the box first Tom then the transfer will wiggle off. You'll need to wind a M8 bolt into the end of the shaft then use a slide hammer to pull it out cos it's held in by a clip.
Read this Untitled Document
