More Gizzmo help
H
Hughandjenny
Tried to input the settings on the Gizzmo boost controller this afternoon, but failed. Followed the instructions that I got with the car (IBC-R BOOST CONTROLLER) but the settings dont seem to stick.
When I read the current settings the programmes 1-5 all 0.00 foe the target boost 10 for the duty cycle and 0 for the gain.
On programme 6 it was reading 0.44 for target boost, 62 duty and 16 gain.
So started with programme 1 followed the sequence, foot down in third and forth. Pulled over and switched off, went into setting 1 and it showed still 0.00. Increased the duty as per instrucyions to 20, but agian after switch off still 0.00.
So decided to go into set up 6. Foot down in third and forth and watching the boost whilst driving was getting 1.2 bar. When switched off and on it does not show the target boost level. When driving in setting 6 the car is noticeably much much quicker.
Does anyone know what I am doing wrong
T
tmus
i don't quite understand what you are doing but on my gizzmo, (IBC)
my duty is on 76, Gain 7, holds 1.25 bar.
steve_fctuning
10duty will do absolutely nothing.. raise it.. but watch your gauge carefully dude :)
H
Hughandjenny
Thanks I will up the duty and keep an eye on the boost. One setting is at about 62 duty and I am getting just over 1.2 bar.
I will experiment
