B
Barrows2005
Hi thanks for looking, firstly I really want to buy the kph to mph converter of ebay... Is this the one that screws/plugs into gearbox.. http://pages.ebay.com/link/?nav=item.view&alt=web&id=191353996755 if so where abouts as the only thing I have located looks like the reverse light switch?
My 2nd more important problem is my coolant bottle is empty... If I put any in the bottle it comes back out when driving, I tried draining the whole system and refilling and bleeding etc like you would with any car to no avail it doesn't over heat and the heaters stay hot on idle and during driving... Is there any other explanation or thing I can try other than thinking the head may be cracked and exhaust gasses are getting in there shooting it back out?
And I should post this next bit on another part I was reading however didn't see it resolved... The ayc is noisy if have been driving less like a grandad and then go round corners... The other post suggests draining and refilling... My ayc light doesn't come on or flicker when driving so is it normal or do I need a refill? Many many thanks.
