invisible
As per title.
On my EVo IX
Noticed checking my expansion tank that not only was the coolant fluid very clear but also low.
I have removed the coolant expansion tank, empotied it and cleaned it out as some gunk in the bottom and have also removed the radiator cap and drain the fluid via the drain plug at bottom of radiator.
Liquid is very clear so I guess the coolant strength very weak.
Is there any reason why I can not use Halfords Advanced long life antifreeze (as have some left from when I did my Golf last weekend). They use an orange colourant I think Mitisi use green iirc?
Any other tips as its a bit differnt to the Golf.
Ie) I assume I refill via the radiator cap directly and not via the expansion tank?
I was planning on filling the radiator (with drain valve closed) to the top, is that correct? Then filling the expansion tank and run the engine with the radiator cap off and squeeze the pipes to release any air and to get the coolant around the system.
Then top up the expansion tank to the max level, warm car and then drain again until liquid comes through the coolant colour, close up and top up radiator and coolant tank. Is this correct as I do not want to over fill.
Also should the heater be set to high but not one when running the engine?
All guidance greatly appreciated
On my EVo IX
