help timing belt !!!!!
F
frankie2531
hi guys just got my evo 4 and wondered when the belts were due as it has 69,000 miles /km on the clock any help would be great :confused:
45k it should be due and again at 80k I guess check for signs of wear or have a look in your book
A
alievo6
take the cam cover off and have a look at the condition of the belt its best to change the water pump at the same time.
Wingnut247
Wingnut247
Agree! If in dout change!! Dont foget balance shaft belt too, i lost an engine to a failed balance shaft belt which took out the cam belt at high rpm! Engine was a total loss!
I'd advice you to get an uprated version like kevlar! Ross sport can sort u out!
gates belts are highly recomended.
and dont forget to change the balance shaft belt :)
EVOIV MJC
EVOIV MJC
If in doubt check the date of the OP.. think this post was in the archive! But i guess the info is useful to others that want top know
ha ha yea, nearly 3 years to answer a simple question :wtf::):)
