STU3YP
- KENT
Hi,
I have a 2005 Evo 8 Mr, UK model.
I have read every thread i can find in the net regarding this and still cant seem to find any instructions.
I have dual fog light switch in it, so front and rear.
The fronts are fitted in the headlights and work correctly.
I assume the rear fog would have been in the rear bumper at some point but there is no longer a fog light fitted to the car.
The rear fog light switch operates the warning light in the cluster.
I have checked the rear and underside of the car and can't find any type of loom or wiring for a fog light.
I have pulled the switches and on the back there is some sort of circuit board added which has a brown and green wire attached. The brown looks like it goes up to the dash so probably powering the warning lights. The green goes down under the scuff panels but I do no know where it runs to or what it is for, as its wrapped with the rest of the loom.
I have an mot due soon and need to get it wired up asap. I am looking to use the empty reverse light in the rear cluster for the fig light. The loom is still wired for reverse.
Any help would be much appreciated, I am sure many poeple will have done this somehow for the same reason.
I have attached pics of the rear of the fig switches and the circuit board albeit wrapped in heat shrink.
