T
Turbo_scotty
Hi all I'm hopeing someone can shed some light in this as im getting to the point of giving up :arms:
I have a 2004 260 8
Basically the car misfires on any load it started off by getting worse and worse and now it won't let you put the car on boost at all or even accelerate at all just bogs down almost feels like car is flooding itself or blowing the spark out
The car has also been awful on petrol lately
Mods are
2.5" downpipe into 3" decat and full system ( decat fitted after this fault due to cat rattleing thought it might be blocked )
Evo 9 intake and air filter
Forge dump valve
Standard map .
Car was smokeing black (over fuel) on idle before I changed lambda and airflow meter
I've changed air flow meter, spark plugs (iridium 0.60) coil packs, injector resistor, lambda and the car is still doin it I get code p0505 but I've changed throttle body for an evo 9 one due to 260 sticky problems so just need to be plugged in
I've also did a boost leak test and couldn't find anything
I recently bought evoscan is there anything I can check as I'm unsure how to use it .
I have a 2004 260 8
Mods are
Forge dump valve
Standard map .
