evo8 and evo4 engine differences
dic
dic
just in the middle of putting the 8 engine in my 4 and can't get the 4 camcover+bracket to fit the 8 engine. should it fit? am i just being simple? also is there anything else i will be having trouble with?
dic
dic
just looked at new cam covers and see they are listed 4-8? so it not the covers fault then. so what has been fitted wrong as the middle metal bracket does not fit either the hole is only slightly out???
Matt-evo-v
Matt-evo-v
Not too sure whether it will be relevant.....
But if the 8 engine is a 260 or MR, I think they have different cams, so maybe this will affect the fitting, I couldn't say for sure though, sorry :D
dic
dic
cheers buddy. but i have since made some calls and the 4 middle/bottom metal cover does not fit the 8 due to water pump being in the way. doh!
Matt-evo-v
Matt-evo-v
Ah ok, I didn't know that......
Learn something new everyday :D
Dave Brennun
Dave Brennun
wont fit pal! water pumps in the way. I know someone that was tryin it a while back.
I think he has worked that one out already Dave!
Do you ever read all the way through????
