Mandy
Hi
Has anyone had a problem with Evo X FQ300 (SST twin clutch) where if you put it under any load (and it doesnt have to be much) it loses power (yet revs high) and you lose one of the twin clutches i.e. either 1, 3 and 5 or 2,4 and 6) - then the engine management light comes on which indicates service required with an exclamation mark (which is the clutch management light). If you pull over and turn the engine off it corrects the problem and can use all gears. I have only just bought the car and have taken it back to the garage but there diagnostic did not show the fault up. This happens every time we take it out but typically didnt happen when the garage too it out (annoying lol).
Also does anyone know how to upgrade the MMCS to a russian version so that you can use video in motion - rather than the uk version where you can only use it at standstill.
Many thanks
Mandy.
Many thanks
Mandy.
