Any updates for us buddy?
The sun should have been up in Texas some time ago!!!
Thanks so much!WOW! Great project and has came along loads hats off to ya buddy keep up the good work![]()
Thanks for the help! I completely removed the outside bleeder valves on both sides and no fluid came out at all, even while pumping the brakes. The pistons did move freely when they were taken out and the seals were replaced. I'm quite confused on this issue. The inside bleeder valves work perfectly.Probably due to it having been neglected for so long buddy.
They are know to corrode / clog up.
Have you tried removing them completely and inspecting them?
Might be a good idea to remove them and see what type of flow you have by bleeding once they are off. Be sure to have a container handy for the overflow.
Hopefully there will be a pressurised flow once they are removed.
If that is the case then what you want to do is get someone to go for a slow manual depresion on the pedal when you have a decent flow coming through.
Whilst that someone is performing that task, you will need get the outer nipple back in place and nip it up real fast. It should work out just fine as long as the timing is synchronised. This needs to be done between the time that the pedal is just starting to go down and before it hits the floor.
If that does not work then you will have to remove the Calliper(s) and bench it / them once more.
I presume that the problem is only on the rears right???
Where the Pistons moving freely when the Callipers were off???
What is the flow like through the inside valves?
Is there any fluid coming through?
If so, is it a miniscule amount coupled with air or straight flow fluid?
Is there any discolouration in the fluid?
I think we figured it out! My calipers were assembled wrong before I got them. The bleeder valves are both supposed to towards the top. On mine the outsides are towards the top but the insides are towards the bottom. I will have to split them in half, swap the inside halves, and reassemble them.
So you're telling me that I've spent the best part of 40 minutes on my phone trying to tap on a tiny key pad, the best possible way of getting to the route of your problem, only to now discover that you had already posted up what I thought the issue was in the first place?
Charming! :wtf:
Thanks again for the help! I will be bleeding them all again next chance I get. I doubt I'll have time tomorrow as I have to take a break from working on the Evo to get my race car ready for a Rallyx on Sunday. I will update this thread once they have all been bleed again.Sorry for getting back to you so late but this is the first chance I've had to log in all day.
The Vacuum pressure is about bang on IMO.
Personally, I tighten them to what I feel is about right. Something you need to have a knack for.
If you have a small Tourque Wrench then you need to go for around 25Nm to 30Nm and no more.
I think I know why you a spongy pedal buddy!:
I suggest that you bleed all 4 Calipers again from scratch and once done, before you start the car, pump the pedal around 5 to 10 times and pull the hand brake up and down around 5 to 10 times whilst doing so.
Unless there's a leak on the Servo, which I very much doubt, that should be the end of the matter.
