evo iv sidelights/tail lights help
warrencross
warrencross
nuneaton
hi could someone give me an idea where i might find the fuse or all the fuses that run the sidelights/taillights on my evo iv or if they even have a relay, the guy who owned it before had just wire them on an on off switch ran directly off the battery not fused i might add i have removed this wire and also have replaced the stalk but still i have no sidelights/taillights /panel lights any pictures of fuses locations and or relays would be greatly appreciated has it might be they have a relay but the idiot before has removed it, any help would be greatly appreciated.
warrencross
warrencross
nuneaton
yeah some numpty before owned it but trying to sort properly they have bogged there own flasher unit in had cut wires from stalk to do it and tapped it up in brown parcel tape lol, ive removed all that , soldered loom and fount the correct flasher in fusebox which was missing and got them working has they should, sme people dnt half bodge things up lol and thanks for your help will have a look
warrencross
warrencross
nuneaton
Tryed to follow wireing does anyone know if it normal for both wires to the sidelights to be both showing negative power and are they supposed to switch when turned on and one thing I defo need to know is are the sidelights on a relay I know the headlights are
warrencross
warrencross
nuneaton
I found if I put like to the green n white wire from stalk or front side light the lights come on so what I need to know is they a relay or something has I have already changed the stalk
warrencross
warrencross
nuneaton
Do evo iv haveva dimmer switch if so where thanks in need of desperate help
warrencross
warrencross
nuneaton
Thanks for all your help im going to sort it tomoz the problem was 3 wires under my drivers wheel arch have melted together due to rubbing throught found the green and yellow wire that powers the stork in the engine fuse box underneath the wire insulation had melted so got to re run new wires through the whole loom all good fun with old cars lol:)
warrencross
warrencross
nuneaton
hi all thanks for all your help i removed the loom and have replaced the burnt out wiring and re insulated the the loom i know have my side lights back . just thought i would let you all know
