Evo iv boost solonoid location
warrencross
warrencross
nuneaton
hi all could someone tell me location of the stock boost solenoid on a evo 4 im trying to locate the stock one and im not sure if its been removed, i recently brought the car but doesn't seem to be boosting properly it had an amcr boost controller on it but i have found the 3 way solenoid valve disconnect but the waste gate is still connected to it, one of the three pipes is missing of the 3 way solenoid, does anyone have a picture of the stock solenoid ive Google but cant find one, i cant even find a stock solenoid on eBay. any help would be greatly apreciated
Stock solenoid is located below battery if you still have it fitted in engine bay. On side of the passenger suspension tower.
Don't bother with refitting it.
If you have a problem with boost then plumb turbo to actuator directly and eliminate any electronic control.
The 3 port should only have 2 pipes to it. The 3rd vents to atmosphere.
warrencross
warrencross
nuneaton
ok thanks rob i did try plugging in the plug on the apexi valve but when i do the car dnt start also the pipe from the top of the bov to the inlet has two little metal taps in it what are these for ? would you know
Ok :what: and you repeated your post with a link to the same thread...
Without pictures you may aswell guess at every answer
A newbie thread to introduce yourself and car may also help...
warrencross
warrencross
nuneaton
Hi rob sorry i was saying ok thanks for the information you provided, i never meant to post twice my internet went off and thought it had not posted, and couldn't see how to delete it ,when i realized.
